[Qgis-user] Offline background map for large regions
abru345 at gmx.de
abru345 at gmx.de
Tue Jul 12 13:04:28 PDT 2022
Thank you!
> The OSM Liberty style is compatible with OpenMapTiles
> https://github.com/maputnik/osm-liberty
I saved them locally, then in the Vector Tiles reader Plugin I added
them in the "GL Style JSON URL" field:
file:///home/qgis/style.json
but they are ignored. Even if I enter a web link
https://maputnik.github.io/osm-liberty/style.json
in the same field it is ignored. The checkbox "Apply GL JSON style" is
checked.
Second thing: nearly all the layers of the opened map are temporary,
everything is lost on restart of QGIS. If I make them permanent one by
one, I get a separate file for each layer...
Are there other ways instead of the Vector Tiles Reader plugin to use
the OpenMapTiles? The native Vector Tiles menu does not like offline data.
I also thought about trying Greg Troxels approach taking osm files from
geofabrik, then osm2pgsql but it seems my system has way too much RAM
for the conversion.
Cheers
Andreas
Am 12.07.22 um 17:21 schrieb pathmapper:
>> Maybe I need a style? But where to get one (as a template), and how to
>> import it, as the vector tiles reader expects a URL?
> and here are some more
> https://github.com/openmaptiles?q=style&type=all&language=&sort=
> Cheers,
> Björn
