[Qgis-user] GRASS r.series - ERROR: Unable to load GDAL library
Andrea Giudiceandrea andreaerdna at libero.it
Sat Jul 16 03:01:46 PDT 2022
> *Nelson Ribeiro*
> /Fri Jul 15 02:52:21 PDT 2022/
Hi Nelson,
did you install QGIS 3.22.8 using the OSGeo4W Standalone Installer or
the OSGeo4W Network Installer? If the latter, have you updated all the
installed packages? If the former, what installer exactly: the
QGIS-OSGeo4W-3.22.8-3.msi or the QGIS-OSGeo4W-3.22.8-4.msi installer?
What format is your raster layer? Does any of the GRASS processing
algorithm work?
Could you please report the whole processing log?
Does GRASS-GIS starts without issue if launched using the shortcut link?
Does the r.series tool works in GRASS-GIS?
I've just tried to run r.series with QGIS 3.22.8 installed using the
QGIS-OSGeo4W-3.22.8-4.msi OSGeo4W Standalone Installer and also
installed using the OSGeo4W Network Installer and there is no issue with
both in my system.
Anyway, right now the new QGIS versions, 3.22.9 and 3.26.1, are
available in OSGeo4W Network Installer and the corresponding new OSGeo4W
Standalone Installers are available at
https://download.qgis.org/downloads/?C=M;O=D
Best regards.
Andrea
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220716/f44bc699/attachment.htm>
