[Qgis-user] Offline background map for large regions
Patrick Dunford enzedrailmaps at gmail.com
Thu Jul 21 01:49:46 PDT 2022
What are you drawing that needs 180 GB of data? That's the whole
question. That's a lot of data for vectors.
In other words going back to my previous point - you do not need to draw
all of the detail at lower scales. Use scaling rules to address that and
performance should show a big increase.
On 21/07/22 08:42, Andreas via Qgis-user wrote:
> Hi Asim,
> meanwhile I found out that creating a spatialite database needs (unlike
>  postgres) only very little RAM for building. On the other side, after
> running a wole day and night on conversion of the  ~30GB osm_europe.pbf
> with ogr2ogr, I have a 180 GB database now which needs minutes to load...
> Don't know if postgres is more performant. Setup is much more
> complicated.
> Regards,
> Andreas
> Am 20.07.22 um 03:43 schrieb Asim:
> > On 7/15/22 4:11 PM, Andreas via Qgis-user wrote:
> >> I think postgres itself is not the problem at all, but the scripts
> that
> >> move the vector tiles into the database. In the instructions for usage
> >> of these import scripts is written that they need at least as much RAM
> >> as the size of the vector file. So I assume it has to load the whole
> >> file into memory before it can be processed.
> > Thank you for the clarification, Andreas.  I'm new to the GIS ecosystem
> > but the OGR FDW seems to be addressing the problem of not having to
> load
> > entire vector data at once: https://github.com/pramsey/pgsql-ogr-fdw.
> > Asim
> Qgis-user mailing list
