[Qgis-user] SOLVED: Offline background map for large regions
Patrick Dunford enzedrailmaps at gmail.com
Fri Jul 22 08:47:10 PDT 2022
You can also apply scale rules when using file based layers on your
computer. Using a DB is great for certain applications, but if it is a
local server on your laptop, you have to weigh up the pros and cons,
since it has just shifted the processing workload from one application
to another, which may or may not result in a net performance gain.
On 22/07/22 21:43, Andreas via Qgis-user wrote:
> Hi,
> finally I got it.
> I will stick with the 180 GB spatialite db (though being a little
> unhappy with the size), but applying a redy-to-go osm style I found on
> the net reduced the details of the lower scales, so it stays useable
> when staying there. The style has only 3 zoom levels, so maybe I'm going
> to look for more. The speed bottleneck at the moment is CPU/GPU power,
> as my laptop has no dedicated GPU.
> Which also works very nicely is the live gps centering function which
> helps keeping the overview. So I can find my current position without
> the need of scrolling to higher scales.
> Thank you all for your kind assistance and the many helpful hints!
> Andreas
> Qgis-user mailing list
