[Qgis-user] Convert huge shapefile to small size
Nicolas Cadieux njacadieux.gitlab at gmail.com
Thu Jul 28 01:48:14 PDT 2022
There is a distinct possibility that the 5GB shape file is corrupt or that it will be if you manipulate it.  It’s too big for the normal shape file format.  I would first save it as a geopackage then stat looking at why the file is so big.
Unless shapes can be simplified without loosing resolution (keep a back up always), you might have to split the file using a field to make multiple files (example splitting a lake file by state).  You may look at the data types.  Perhaps they can be simplified (ex int16 vs float64 for a filed that has no decimal values…
Try compressing the resulting file.
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 27 juill. 2022 à 22:47, krishna Ayyala via Qgis-user <qgis-user at lists.osgeo.org> a écrit :
> Hello,
> I have a shapefile of 5GB in size. Is it possible to convert this shapefile to a smaller size file? It can be any format, not necessarily a shapefile. But, preferably a vector format. I tried to convert it into tiles, but that didn't work as it was losing the resolution. I am looking to convert this 5GB size file to about 500MB.
> Regards.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220728/e703596f/attachment.htm>
