[Qgis-user] Sync / Reconcile Data in Postgres
Andrew Hughes ahhughes at gmail.com
Mon Jun 6 20:29:30 PDT 2022
Hi All,
I have several third-party living datasets (accessible via web services)
that I need to replicate to an internal postgres instance (ETL processes).
My question is, given my script/model has obtained a copy of the dataset.
What would you recommend I use to synchronize the new/freshly downloaded
data with the older data in the postgres database? In other words, how do I
sync/reconcile the database.
I have looked at the Export to postgres
<https://docs.qgis.org/3.22/en/docs/user_manual/processing_algs/qgis/database.html#export-to-postgresql>,
but this doesn't seem like the right approach. It can overwrite (i.e. drop,
create) a table but this is not a suitable option. It does not document
what it does if it finds a duplicate primary key/constraint either...
(perhaps it does an upsert or maybe it just fails)?
Alternatively, there is a Postgres Execute SQL
<https://docs.qgis.org/3.22/en/docs/user_manual/processing_algs/qgis/database.html#postgresql-execute-sql>
algorithm,
but that requires me to hand code all the sql statements in my script.
Do-able, but not elegant.
Advice would be greatly appreciated.
Thanks for reading,
Andrew
isn't documented unfortunately does not offer this. All it does is
drop/recreate the
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220607/4e4bdc50/attachment.htm>
