[Qgis-user] digitizing
Patrick Dunford
enzedrailmaps at gmail.com
Thu Jun 16 23:13:08 PDT 2022
There are some times when the libraries can run out of memory if a
raster is very large, so you can have something that something like a
graphics editor e.g Gimp can open OK but Qgis coujld have trouble
opening it.
On 17/06/22 14:22, Firstname Lastname wrote:
> I think that there is something wrong with the Tif file I was using.
> I had the same problem with a couple of files but I went back to the
> source file and redid the referencing and it is ok.
> On Thu, Jun 16, 2022 at 7:46 PM Patrick Dunford via Qgis-user
> <qgis-user at lists.osgeo.org> wrote:
> This is a generic answer, as more information would be needed to
> determine exactly the situation you are experiencing.
> If you zoom to the layer, is it then displayed in the same place
> as the rest of your map?
> My recollection of the georeferencer is it produces a world file
> to go with the layer. This should have the correct top-left
> coordinates and pixel resolution in it. Is there also an XML file
> that specifies the CRS?
> Look at the layer name where it is loaded in the GIS and see if
> there is a question mark displayed next to its name, that
> indicates QGIS doesn't have enough information to position the
> layer, such as the information that is stored in sidecar files.
> It is also possible if the file is very large that it will be slow
> to display. Also have a look at the error log at the bottom of the
> screen to see if any error messages are displayed.
> On 17/06/22 04:23, Firstname Lastname via Qgis-user wrote:
>> i have been successfully using the georeferencer for some time.
>> i referenced several maps and they succesfully georeferenced
>> and displayed for me.
>> Then, i was digitizing and i ran the georeference tool and for
>> some reason, the new referenced maps do not display. i have
>> exited and tried to georef in a new project and made sure that i
>> have the same CRS for the basemap and the georef tool but when i
>> run the referencer, the layer appear but the map will not
>> display. i have tried restarting, clearing the georef tool and
>> running again but i get the same result. Does anyone know what
>> i am doing wrong and why my referenced maps will not display?
>> Byron Veilleux, MSc. P.Geo
>> Conjugate Geologic Services Limited
>> Calgary, Alberta Canada
>> byron at conjugategeo.com
>> Cell:4037108414
>> Qgis-user mailing list
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Cell:4037108414
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220617/918beaf7/attachment.htm>
