[Qgis-user] Symbology
Allan Younger ahyounger at iinet.net.au
Fri Jun 17 18:51:11 PDT 2022
I'm trying to show assay results as simple dot plots as graduated colour
and size scaled points based on a selected element.
Problem is that in the layer properties/symbology tab, I cannot select
anything.
Had the problem in Madeira 3.4 & assumed was just a glitch that had
developed in that copy over time.
Installed 3.22.7, same problem.
Csv file has 162000 records & 30 column with co-ords for every point;
with locations plotting a-ok.
Cheers
Allan Younger
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220618/5be4baaa/attachment.htm>
