[Qgis-user] Symbology
chris hermansen clhermansen at gmail.com
Fri Jun 17 19:24:13 PDT 2022
Allan and list,
On Fri, Jun 17, 2022 at 7:00 PM Allan Younger via Qgis-user <
qgis-user at lists.osgeo.org> wrote:
> Hi,
> I'm trying to show assay results as simple dot plots as graduated colour
> and size scaled points based on a selected element.
> Problem is that in the layer properties/symbology tab, I cannot select
> anything.
> Had the problem in Madeira 3.4 & assumed was just a glitch that had
> developed in that copy over time.
> Installed 3.22.7, same problem.
> Csv file has 162000 records & 30 column with co-ords for every point; with
> locations plotting a-ok.
> At the top of the Layer Properties > Symbology dialogue window, have you
selected one of the options other than "No Symbols"?  For example,
"Graduated"?
Then in the field Value one of your layer's attributes?
Then pressed the "Classify" button?
Chris Hermansen · clhermansen "at" gmail "dot" com
C'est ma façon de parler.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220617/4c25deff/attachment.htm>
