[Qgis-user] Dimensioning in QGIS
chris hermansen clhermansen at gmail.com
Fri Jun 24 12:18:13 PDT 2022
Nicolas, everyone,
Sorry to top post here but I'm not sure where to start below.
What about just using the various drawing tools on the print layout?
Arrows can be added, annotation, polylines, that sort of thing?  Of course
it's not in the original data / layers, but is that important?
On Fri, Jun 24, 2022 at 9:27 AM Nicolas Cadieux via Qgis-user <
qgis-user at lists.osgeo.org> wrote:
> Hi,
> Qgis is not a CAD as you are discovering.  Others have given you good
> plugins and tools so I will not add to that.  You can still do “3D” as 3D
> objects like lines, points and polygon are supported.  You can use the 3D
> map windows to visualize the 3D objects and a DEM  raster or mesh layers.
> I too am an archaeologist.  In the past, I have used simple 3D WKT format
> in a text file to make 3D outlines of trenches and survey holes. Looks like
> some plugins can now do that for you now.  QGIS is not quite there as a
> full blown CAD but it’s as good as current Commercial GIS I have worked
> with.  Progress has been slow but steady.
> Nicolas Cadieux
> https://gitlab.com/njacadieux
> Le 24 juin 2022 à 08:03, Zoltán Siki via Qgis-user <
> qgis-user at lists.osgeo.org> a écrit :
> you can solve it using Geometry Generator see:
> https://stuyts.xyz/2018/11/05/qgis-geometry-generator-examples-repository/
> Regards,
> Zoltan
> IainS via Qgis-user <qgis-user at lists.osgeo.org> ezt írta (időpont: 2022.
> jún. 23., Cs, 23:44):
>> Is there a tool for adding dimensions in QGIS. For those who are
>> wondering what I am talking about, it is common in CAD drafting to add
>> dimensions to what you have drawn and this is a whole part of a CAD program
>> where you can format dimensions …etc.
>> I have been asked to add dimensions to an archaeological hole I am
>> digging on a QGIS map and I was wondering whether there is a similar
>> dimensioning tool in QGIS.
>> Cheers
>> *Dr Iain Stuart*
>> *JCIS Consultants *
>> P.O. Box 2397
>> Burwood North
>> NSW, 2134
>> (02) 9701 0191
>> (0413) 380116 (m)
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Üdv.
> Siki Zoltán
Chris Hermansen · clhermansen "at" gmail "dot" com
C'est ma façon de parler.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220624/4161fa7e/attachment.htm>
