[Qgis-user] Dimensioning in QGIS
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Fri Jun 24 13:20:18 PDT 2022
Hi Chris,
Dimensions here are not annotations. I believe the original post was
referring to what AutoCad refers to as "Extrude" as seen here
https://www.youtube.com/watch?v=PdysbeHHXo8.
Cheer!
Nicolas
On 2022-06-24 3:18 p.m., chris hermansen wrote:
> Nicolas, everyone,
> Sorry to top post here but I'm not sure where to start below.
> What about just using the various drawing tools on the print layout?
> Arrows can be added, annotation, polylines, that sort of thing? Of
> course it's not in the original data / layers, but is that important?
> On Fri, Jun 24, 2022 at 9:27 AM Nicolas Cadieux via Qgis-user
> <qgis-user at lists.osgeo.org> wrote:
> Hi,
> Qgis is not a CAD as you are discovering. Others have given you
> good plugins and tools so I will not add to that. You can still
> do “3D” as 3D objects like lines, points and polygon are
> supported. You can use the 3D map windows to visualize the 3D
> objects and a DEM raster or mesh layers. I too am an
> archaeologist. In the past, I have used simple 3D WKT format in a
> text file to make 3D outlines of trenches and survey holes. Looks
> like some plugins can now do that for you now. QGIS is not quite
> there as a full blown CAD but it’s as good as current Commercial
> GIS I have worked with. Progress has been slow but steady.
> Nicolas Cadieux
> https://gitlab.com/njacadieux
>> Le 24 juin 2022 à 08:03, Zoltán Siki via Qgis-user
>> <qgis-user at lists.osgeo.org> a écrit :
>> you can solve it using Geometry Generator see:
>> https://stuyts.xyz/2018/11/05/qgis-geometry-generator-examples-repository/
>> Regards,
>> Zoltan
>> IainS via Qgis-user <qgis-user at lists.osgeo.org> ezt írta
>> (időpont: 2022. jún. 23., Cs, 23:44):
>> Is there a tool for adding dimensions in QGIS. For those who
>> are wondering what I am talking about, it is common in CAD
>> drafting to add dimensions to what you have drawn and this is
>> a whole part of a CAD program where you can format dimensions
>> …etc.
>> I have been asked to add dimensions to an archaeological hole
>> I am digging on a QGIS map and I was wondering whether there
>> is a similar dimensioning tool in QGIS.
>> Cheers
>> *Dr Iain Stuart*
>> */JCIS Consultants /*
>> P.O. Box 2397
>> Burwood North
>> NSW, 2134
>> (02) 9701 0191
>> (0413) 380116 (m)
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Üdv.
>> Siki Zoltán
> Chris Hermansen · clhermansen "at" gmail "dot" com
> C'est ma façon de parler.
Nicolas Cadieux
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220624/1f6d5bc0/attachment.htm>
