[Qgis-user] shapefile import error
David Witton dhwitton at gmail.com
Thu Mar 3 15:13:51 PST 2022
'Repair Shapefile' did the trick. Only problem now is the DEM is up in
Alberta instead of in Idaho. Must be a CRS error somewhere.
On Thu, Mar 3, 2022 at 2:52 PM Nicolas Cadieux <njacadieux.gitlab at gmail.com>
wrote:
> Hi,
> You could try checking the drive for errors.  I think there may be a
> shapefile checking tool in processing???  I think I saw something lately
> when searching for « fix » or « repair » under processing.  Never used it.
> I don’t have a computer to check.  Could be my imagination working….
> Nicolas Cadieux
> https://gitlab.com/njacadieux
> Le 3 mars 2022 à 11:31, David Witton <dhwitton at gmail.com> a écrit :
> Hello
> I'm pointing the Data source Manager|Vector at a .shp file and getting the
> error "Invalid Data Source". The file exists on an external drive, and the
> path is valid - any ideas on what could be causing this?
> David Witton
> 307 413 2072
> Qgis-user mailing list
David Witton
307 413 2072
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220303/6a9b67d4/attachment.html>
