[Qgis-user] shapefile import error
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Thu Mar 3 20:19:09 PST 2022
Nice to know that tool did in fact exist. Just right click on the layer and you should be able to define the layer crs. Do not use “save as” or “export” to do this as such options would reproject the file in a new crs. You first need to correct or specify the proper crs. Maybe it’s in the metadata.
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 3 mars 2022 à 18:14, David Witton <dhwitton at gmail.com> a écrit :
> 'Repair Shapefile' did the trick. Only problem now is the DEM is up in Alberta instead of in Idaho. Must be a CRS error somewhere.
>> On Thu, Mar 3, 2022 at 2:52 PM Nicolas Cadieux <njacadieux.gitlab at gmail.com> wrote:
>> Hi,
>> You could try checking the drive for errors. I think there may be a shapefile checking tool in processing??? I think I saw something lately when searching for « fix » or « repair » under processing. Never used it. I don’t have a computer to check. Could be my imagination working….
>> Nicolas Cadieux
>>>> Le 3 mars 2022 à 11:31, David Witton <dhwitton at gmail.com> a écrit :
>>> Hello
>>> I'm pointing the Data source Manager|Vector at a .shp file and getting the error "Invalid Data Source". The file exists on an external drive, and the path is valid - any ideas on what could be causing this?
>>> David Witton
>>> 307 413 2072
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> David Witton
> 307 413 2072
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220303/edbca3c2/attachment.html>
