[Qgis-user] Extending an existing line with the vertex tool - combination with tracing possible?
Nicolas Cadieux njacadieux.gitlab at gmail.com
Thu Mar 3 20:12:44 PST 2022
To my knowledge, when using the vertex tool, you click on the last node and then, you can extend it once.  I think you need to reclick the last node again if you want to add a new point.  I don’t do much vectorizing lately and in the past, used AutoCAD to do it. There must be some other way of doing it. Maybe there is a shortcut or something like the shift key we need to use.  I would check the user manual to see if there is an option under the vertex tool.  I see that lots of new tools have been added lately making QGIS a good contender for tracing.  I guess you could just create a new line and then merge both together.
Just my grain of salt…
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 1 mars 2022 à 05:24, Andreas Neumann <a.neumann at carto.net> a écrit :
> Hi,
> When I am extending an existing line with the vertex tool (by enabling the vertex tool and clicking on the small "plus" symbol), can I then still activate the "tracing" functionality to follow along other features?
> If yes, I haven't found out how - any hints would be appreciated a lot!
> Thanks,
> Andreas
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220303/6115f73c/attachment.html>
