[Qgis-user] Extending an existing line with the vertex tool - combination with tracing possible?
Simon Dietmann
simon.dietmann at pgnu.de
Fri Mar 4 00:29:40 PST 2022
Hi Andreas,
as a workaround for your problem I would suppose you draw a new line feature using the tracing function and then merge it with the one you want to extend.
That should work without any problem.
Simon Dietmann
M.Sc. Physische Geografie
Von: Qgis-user <qgis-user-bounces at lists.osgeo.org> Im Auftrag von Nicolas Cadieux via Qgis-user
Gesendet: Freitag, 4. März 2022 05:13
An: Andreas Neumann <a.neumann at carto.net>
Cc: QGIS User List <qgis-user at lists.osgeo.org>
Betreff: Re: [Qgis-user] Extending an existing line with the vertex tool - combination with tracing possible?
To my knowledge, when using the vertex tool, you click on the last node and then, you can extend it once. I think you need to reclick the last node again if you want to add a new point. I don’t do much vectorizing lately and in the past, used AutoCAD to do it. There must be some other way of doing it. Maybe there is a shortcut or something like the shift key we need to use. I would check the user manual to see if there is an option under the vertex tool. I see that lots of new tools have been added lately making QGIS a good contender for tracing. I guess you could just create a new line and then merge both together.
Just my grain of salt…
Nicolas Cadieux
https://gitlab.com/njacadieux
Le 1 mars 2022 à 05:24, Andreas Neumann <a.neumann at carto.net> a écrit :
When I am extending an existing line with the vertex tool (by enabling the vertex tool and clicking on the small "plus" symbol), can I then still activate the "tracing" functionality to follow along other features?
If yes, I haven't found out how - any hints would be appreciated a lot!
Thanks,
Andreas
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220304/a46ef953/attachment.html>
