[Qgis-user] Extending an existing line with the vertex tool - combination with tracing possible?
Andreas Neumann
a.neumann at carto.net
Fri Mar 4 00:38:45 PST 2022
Hi Simon and Nicolas,
Yes, that was our idea, too - to merge two or more lines that share
their start/end vertices.
But unfortunately, this doesn't work for us, because we edit in a very
complex data model and QGIS doesn't preserve feature Ids when merging
features --> all of our DB relations would then fail.
See https://github.com/qgis/QGIS/issues/47629
I asked our commercial support provider to hopefully fix this issue ...
then we could go the "merge route".
Andreas
On 2022-03-04 09:29, Simon Dietmann via Qgis-user wrote:
> Hi Andreas,
> as a workaround for your problem I would suppose you draw a new line
> feature using the tracing function and then merge it with the one you
> want to extend.
> That should work without any problem.
> Simon Dietmann
> M.Sc. Physische Geografie
> Von: Qgis-user <qgis-user-bounces at lists.osgeo.org> Im Auftrag von
> Nicolas Cadieux via Qgis-user
> Gesendet: Freitag, 4. März 2022 05:13
> An: Andreas Neumann <a.neumann at carto.net>
> Cc: QGIS User List <qgis-user at lists.osgeo.org>
> Betreff: Re: [Qgis-user] Extending an existing line with the vertex
> Hi,
> To my knowledge, when using the vertex tool, you click on the last node
> and then, you can extend it once. I think you need to reclick the last
> node again if you want to add a new point. I don't do much vectorizing
> lately and in the past, used AutoCAD to do it. There must be some other
> way of doing it. Maybe there is a shortcut or something like the shift
> key we need to use. I would check the user manual to see if there is
> an option under the vertex tool. I see that lots of new tools have
> been added lately making QGIS a good contender for tracing. I guess
> you could just create a new line and then merge both together.
> Just my grain of salt...
> Nicolas Cadieux
> https://gitlab.com/njacadieux
>> Le 1 mars 2022 à 05:24, Andreas Neumann <a.neumann at carto.net> a écrit
>> Hi,
>> When I am extending an existing line with the vertex tool (by enabling
>> the vertex tool and clicking on the small "plus" symbol), can I then
>> still activate the "tracing" functionality to follow along other
>> features?
>> If yes, I haven't found out how - any hints would be appreciated a
>> lot!
>> Thanks,
>> Andreas
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220304/9e742f93/attachment.html>
