[Qgis-user] QGIS - repeated connections
Andreas Neumann
a.neumann at carto.net
Wed Mar 9 04:17:46 PST 2022
Yes, you can limit the nr of CPU cores that render in QGIS - and this
will limit the PG connections.
Menu "Settings" --> "Options" --> "Rendering".
If you disable the checkbox "Render layers in parallel using many CPU
cores", this will force QGIS to go single threaded for drawing - or you
can use the setting to the right of it and set it to use max 2 CPU
cores, which will restrict it to two connectsions max.
The much better solution, however, would be to use a connection pool
solution (like pgBouncer). Then the idle connections will be temporarily
disconnected from the PG server. See the pgBouncer documentation.
Greetings,
Andreas
On 2022-03-09 12:23, Mauricio Vieira Cardoso Filho via Qgis-user wrote:
> Hi Alexandre,
> Thanks for the answer. Is there any way to prevent this from happening?
> - I ask because I have many users who connect to the postgres database
> through QGIS and for each user connection, it is generating five
> connection sessions in the database. And that has killed Postgres's
> performance. Is there a way to prevent QGIS from generating this amount
> of connections?
> Best Regards
> Maurício Vieira Cardoso Filho
> Gerente TI Infra
> Tel: +556137995051
> email : mcardoso at topocart.com.br;
> skype: mauricio.cardoso1974
> Em ter., 8 de mar. de 2022 às 23:36, Alexandre Neto
> <senhor.neto at gmail.com> escreveu:
> Hello Mauricio,
> That is "normal". Several different components of QGIS can establish
> different and independent connections to PostgreSQL. For example, the
> browser panel can create a connection, the database manager another,
> and so on.
> Alexandre Neto
> A terça, 8/03/2022, 20:14, Mauricio Vieira Cardoso Filho via Qgis-user
> <qgis-user at lists.osgeo.org> escreveu:
> I use QGIS 3.16 and I'm having an operation that I believe to be
> abnormal. I use QGIS connected to a postgres database. My problem is
> that QGIS is creating five simultaneous connections for each database
> user. (For example, when opening qgis and connecting to the bank, on my
> server I have five connections created with my username). Does anyone
> have any idea what could be happening?
> Best
> Gerente TI Infra
> Tel: +556137995051
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220309/7fc465dd/attachment.html>
