[Qgis-user] Automating creation of county distribution maps
Mike Breiding - Morgantown WV epicroadtrips at gmail.com
Fri Mar 11 12:50:34 PST 2022
I had the range USA range map in the screen shot and have since updated
it.  https://photos.app.goo.gl/ktn5quT6s6SRwrzBA
WV-Mike
On 3/10/2022 11:04 AM, chris hermansen wrote:
> Perhaps others are better understanding how you want to visualize the
> distributions, but what I get from your description is that if you have
> 100 (or 2500) species then you will have 100 (or 2500) maps, which
> sounds unwieldy to me.
I neglected to mention the use for the distribution maps.
They will be used in a print brochure.
A page mock up can be seen here:
The USA distribution map in the mock up was made in Qgis using the
information from:
https://plants.usda.gov/home/plantProfile?symbol=BODI2
This is interactive and will display down to the state and county level.
However, they are not up to date at the state/county level. If they were
I would simply make a screen shot and that would be the end of it.
The state distribution map used in the mock up was made using Qgis based
on data from the West Virginia University Herbarium which has the most
up to date information on distribution.
WV-Mike
