[Qgis-user] Automating creation of county distribution maps
Jésahel Benoist djes1975 at gmail.com
Sat Mar 12 01:04:31 PST 2022
Hello Mike,
I tried to follow your question and the most I read the less I understand !
Could you simply explain what you want to see, what action the user have to
do and what he gets?
For this, try to give input data and what will link them : plants (table
with plant name and states distribution?), states (geometric data with
states names?), columns to link...
The good point is that I'm sure QGIS can do this. But nobody will engage
work if objective isn't precise enough.
Regards,
J. B.
Le ven. 11 mars 2022 à 21:50, Mike Breiding - Morgantown WV via Qgis-user <
qgis-user at lists.osgeo.org> a écrit :
> I had the range USA range map in the screen shot and have since updated
> it.  https://photos.app.goo.gl/ktn5quT6s6SRwrzBA
> WV-Mike
> On 3/10/2022 11:04 AM, chris hermansen wrote:
> > Perhaps others are better understanding how you want to visualize the
> > distributions, but what I get from your description is that if you have
> > 100 (or 2500) species then you will have 100 (or 2500) maps, which
> > sounds unwieldy to me.
> I neglected to mention the use for the distribution maps.
> They will be used in a print brochure.
> A page mock up can be seen here:
> The USA distribution map in the mock up was made in Qgis using the
> information from:
> https://plants.usda.gov/home/plantProfile?symbol=BODI2
> This is interactive and will display down to the state and county level.
> However, they are not up to date at the state/county level. If they were
> I would simply make a screen shot and that would be the end of it.
> The state distribution map used in the mock up was made using Qgis based
> on data from the West Virginia University Herbarium which has the most
> up to date information on distribution.
> WV-Mike
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220312/91a9c0dc/attachment.html>
