[Qgis-user] OTB Plugin Activation
Nicolas Cadieux njacadieux.gitlab at gmail.com
Sat Mar 12 09:10:49 PST 2022
I am currently with QGIS 3.22.2. my version of the OrfeoToolbox provider
is 2.12.99. Under Processing Toolbox/options/providers/OTB, I see OTB
application folder. It is set to
C:/OTB-7.4.0-Win64/lib/otb/applications.  OTB folder is set to
C:/OTB-7.4.0-Win64.  If you don't have the right folders, it will not
work.  I see no "activate box".  Set the folder then click ok. Close the
Option panel and reopen it to make sure the setting have been
accepted.   If the first folder was the most complicated to set correctly.
Nicolas
On 2022-03-12 8:12 a.m., martin.bittens at gmx.de wrote:
> The OTB settings are not accessable. I can see the fields but when I
> clicked on it nothing happened.
> Regards
> Martin
> Am 12.03.2022 1:20 AM schrieb Nicolas Cadieux
> <njacadieux.gitlab at gmail.com>:
>     Hi,
>     Y did you indicate the directory paths for the binaries in the
>     processing options?
>     Nicolas Cadieux
>     https://gitlab.com/njacadieux
>         Le 11 mars 2022 à 09:52, Martin Bittens via Qgis-user
>         <qgis-user at lists.osgeo.org> a écrit :
>         Hello QGIS Users,
>         I am running QGIS 3.22.4 and 3.24.0 and I tried to activate
>         the OTB
>         plugin processing the following steps:
>         1. Downloading the Orfeo Toolbox (version 7.4.0) as zip file;
>         2. Unpacking the zip file;
>         3. Opening QGIS;
>         4. Checking in the plug in manager if the Orfeo Toolbox
>         Provider is
>         enabled (it was);
>         5. Opening the Options --> Processing --> Providers --> OTB
>         But there the "Activate' checkbox  did not appear.
>         Does anybody know is going wrong?
>         Many thanks for your help.
>         Regards
>         Martin
>         This email has been checked for viruses by Avast antivirus
>         software.
>         https://www.avast.com/antivirus
>         _______________________________________________
>         Qgis-user mailing list
>         Qgis-user at lists.osgeo.org
>         List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>         Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Nicolas Cadieux
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220312/5f0181ba/attachment.html>
