[Qgis-user] OTB Plugin Activation
Martin Bittens martin.bittens at gmx.de
Tue Mar 15 03:49:14 PDT 2022
Hello Nicolas,
thanks a lot for your advice. The OTB-plugin is working now. I must
admit that I made a mistake when I tried entering the path to the OTB
binaries. I clicked directly on the respective OTB fields in the
processing --> settings --> OTB tab (e.g., 'OTB application folder'). As
I wrote nothing happened then. But I had to move the cursor in the white
space beside the fields and double click there. Then a menu opened where
I could enter/select the correct OTB paths
Again, many thanks
Martin
Am 3/12/2022 um 2:10 PM schrieb Nicolas Cadieux:
> Hi,
> I am currently with QGIS 3.22.2. my version of the OrfeoToolbox
> provider is 2.12.99. Under Processing Toolbox/options/providers/OTB, I
> see OTB application folder. It is set to
> C:/OTB-7.4.0-Win64/lib/otb/applications.  OTB folder is set to
> C:/OTB-7.4.0-Win64.  If you don't have the right folders, it will not
> work.  I see no "activate box".  Set the folder then click ok. Close
> the Option panel and reopen it to make sure the setting have been
> accepted.   If the first folder was the most complicated to set correctly.
> Nicolas
> On 2022-03-12 8:12 a.m., martin.bittens at gmx.de wrote:
>> The OTB settings are not accessable. I can see the fields but when I
>> clicked on it nothing happened.
>> Regards
>> Martin
>> Am 12.03.2022 1:20 AM schrieb Nicolas Cadieux
>> <njacadieux.gitlab at gmail.com>:
>>     Hi,
>>     Y did you indicate the directory paths for the binaries in the
>>     processing options?
>>     Nicolas Cadieux
>>     https://gitlab.com/njacadieux
>>         Le 11 mars 2022 à 09:52, Martin Bittens via Qgis-user
>>         <qgis-user at lists.osgeo.org> a écrit :
>>         Hello QGIS Users,
>>         I am running QGIS 3.22.4 and 3.24.0 and I tried to activate
>>         the OTB
>>         plugin processing the following steps:
>>         1. Downloading the Orfeo Toolbox (version 7.4.0) as zip file;
>>         2. Unpacking the zip file;
>>         3. Opening QGIS;
>>         4. Checking in the plug in manager if the Orfeo Toolbox
>>         Provider is
>>         enabled (it was);
>>         5. Opening the Options --> Processing --> Providers --> OTB
>>         But there the "Activate' checkbox  did not appear.
>>         Does anybody know is going wrong?
>>         Many thanks for your help.
>>         Regards
>>         Martin
>>         This email has been checked for viruses by Avast antivirus
>>         software.
>>         https://www.avast.com/antivirus
>>         _______________________________________________
>>         Qgis-user mailing list
>>         Qgis-user at lists.osgeo.org
>>         List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>         Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Nicolas Cadieux
This email has been checked for viruses by Avast antivirus software.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220315/25dbaa82/attachment.html>
