[Qgis-user] Archivo de texto a QGIS
Nicolas Orellana nicolas.orellana.s at gmail.com
Tue Mar 15 16:53:13 PDT 2022
hola, una ayuda con la siguiente consulta:
necesito lleva un archivo de texto con polilíneas de la siguiente
estructura:
ITEM;ID_Tramo_cable_óptico;Codigo_Tramo_cable_óptico;Cantidad_Fibras;Longitud_Estimada_Total;Columna1
1;259970;LANG ATP CAP 15 96 F.O. PKP;96;569,25;-72.3473131297419
-37.4693619484954, -72.3472535235808 -37.469363950168, -72.3472616153805
-37.4695764171866, -72.3472706302872 -37.4699298355154, -72.3472831573845
-37.4702763430984, -72.3472901695875 -37.470366410894, -72.3471088478767
-37.4703303839892
2;268863;LANG ATP CAP 15 32 F.O PKP;32;317,9;-72.3419967317581
-37.4693365347936, -72.3418583028969 -37.4693147526957, -72.3418169714269
-37.469275277813, -72.341675418789 -37.4692472316387, -72.3412370260197
-37.4691627415692, -72.3407012104658 -37.4690533899232, -72.3406957666341
-37.469049726257,
3;276549;LANG ATP-CAP14 256 F.O.;256;558,34;-72.3607871576207
-37.4691957684416, -72.360780359542 -37.4692246441514, -72.3608072780816
-37.4692281371511, -72.3616168271908 -37.4694057148484, -72.3616229393526
-37.4694181824697, -72.3624055391924 -37.4695956598269, -72.3630246152763
-37.469739721667
a QGIS.
de antemano muchas gracias.
Hello, help with the following query: I need a text file with lines of the
following structure:
ITEM;ID_Optical_cable_Span;Code_Optical_cable_Span;Amount_Fibers;Total_Estimated_Length;Column1
1;259970;LANG ATP CAP 15 96 F.O. PKP; 96; 569.25; -72.3473131297419
-37.4703303839892
2; 268,863; LANG ATP CAP 15 32 FO PKP; 32; 317.9; -72.3419967317581
-37.469049726257,
3; 276,549; LANG ATP-CAP14 FO 256; 256; 558.34; -72.3607871576207
-37.4694181824697, -72.3624055391924 -37.4695956598269, -72.3630246152763 -
37.469739721667
to QGIS.
Beforehand thank you very much.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220315/c7dc2400/attachment.html>
