[Qgis-user] Archivo de texto a QGIS
chris hermansen clhermansen at gmail.com
Tue Mar 15 19:24:29 PDT 2022
Nicolás and list,
On Tue, Mar 15, 2022, 16:54 Nicolas Orellana via Qgis-user <
qgis-user at lists.osgeo.org> wrote:
> hola, una ayuda con la siguiente consulta:
> necesito lleva un archivo de texto con polilíneas de la siguiente
> estructura:
Nicolás, has revisado este how to, que explica el uso de CSV y linestrings?
https://gis.stackexchange.com/questions/287731/create-line-from-csv-coordinates#:~:text=Open%20QGIS%20and%20select%20the,and%20%22Lat%22%2C%20respectively
Te sirve? O necesitas más?
> ITEM;ID_Tramo_cable_óptico;Codigo_Tramo_cable_óptico;Cantidad_Fibras;Longitud_Estimada_Total;Columna1
> 1;259970;LANG ATP CAP 15 96 F.O. PKP;96;569,25;-72.3473131297419
> -37.4693619484954, -72.3472535235808 -37.469363950168, -72.3472616153805
> -37.4695764171866, -72.3472706302872 -37.4699298355154, -72.3472831573845
> -37.4702763430984, -72.3472901695875 -37.470366410894, -72.3471088478767
> -37.4703303839892
> 2;268863;LANG ATP CAP 15 32 F.O PKP;32;317,9;-72.3419967317581
> -37.4693365347936, -72.3418583028969 -37.4693147526957, -72.3418169714269
> -37.469275277813, -72.341675418789 -37.4692472316387, -72.3412370260197
> -37.4691627415692, -72.3407012104658 -37.4690533899232, -72.3406957666341
> -37.469049726257,
> 3;276549;LANG ATP-CAP14 256 F.O.;256;558,34;-72.3607871576207
> -37.4691957684416, -72.360780359542 -37.4692246441514, -72.3608072780816
> -37.4692281371511, -72.3616168271908 -37.4694057148484, -72.3616229393526
> -37.4694181824697, -72.3624055391924 -37.4695956598269, -72.3630246152763
> -37.469739721667
> a QGIS.
> de antemano muchas gracias.
> Hello, help with the following query: I need a text file with lines of the
> following structure:
> ITEM;ID_Optical_cable_Span;Code_Optical_cable_Span;Amount_Fibers;Total_Estimated_Length;Column1
> 1;259970;LANG ATP CAP 15 96 F.O. PKP; 96; 569.25; -72.3473131297419
> -37.4703303839892
> 2; 268,863; LANG ATP CAP 15 32 FO PKP; 32; 317.9; -72.3419967317581
> -37.469049726257,
> 3; 276,549; LANG ATP-CAP14 FO 256; 256; 558.34; -72.3607871576207
> -37.4694181824697, -72.3624055391924 -37.4695956598269, -72.3630246152763 -
> 37.469739721667
> to QGIS.
> Beforehand thank you very much.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220315/a3b694e5/attachment.html>
