[Qgis-user] points to polygons conversion
Nicolas Cadieux njacadieux.gitlab at gmail.com
Wed Mar 16 19:03:34 PDT 2022
Unfortunately,  the $geometry field with the original polygons no longer
exists.  Layers only have one geometry field at a time unless you
specifically create something like a wkt of wkb field.
If it's was a regular grid, then yes, you could recreate it using
vector/research tools/create grid.  As suggested, a Voronoi Polygons
could work or maybe a tin mesh...  If you are on Windows 10 and have
activated the file versioning, maybe you have an old copy of the file.
Nicolas
On 2022-03-16 12:08 p.m., chris hermansen via Qgis-user wrote:
> Francesca and list,
> On Wed, Mar 16, 2022, 03:06 Francesca Parente via Qgis-user
> <qgis-user at lists.osgeo.org> wrote:
>     Hello group,
>     I'd have a question I hope it doesn't sound too nonsense to you:
>     I'm working on a points shapefile, which I know has been created
>     by centroids of polygons- but I don't have access to polygonal areas.
>     I would need to select just those in some locations and recover
>     their original area within polygonal borders.
>     Is there a chance I can get it done by having this shapefile of
>     centroids only?!
> Polygon centroids aren't necessarily inside polygons, so selecting
> centroids that fall within other areas doesn't mean the original
> polygons would also lie within those areas.
> Also if you are trying to determine the proportion of the original
> polygons within the other areas (the intersections of the two sets)
> you must have the original polygons.
> I doubt that answers achieved with only the centroids would provide
> any meaningful results.
> Chris
> Qgis-user mailing list
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
Nicolas Cadieux
https://gitlab.com/njacadieux
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220316/75d37cef/attachment.html>
