[Qgis-user] Qgis-user Digest, Vol 193, Issue 43
Dom O dom225 at gmail.com
Fri Mar 18 15:01:50 PDT 2022
Andrea it looks like the problem is an abandoned/unmaintainedGRASS plugin and people are using the processing toolbox GRASS instead...
> On Mar 18, 2022, at 12:00 PM, qgis-user-request at lists.osgeo.org wrote:
> Send Qgis-user mailing list submissions to
> 	qgis-user at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> 	https://lists.osgeo.org/mailman/listinfo/qgis-user
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> 	qgis-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Qgis-user digest..."
> Today's Topics:
>   1. Trouble loading Grass in QGIS (learning thru the QGIS
>      training modules) (Dom O)
>   2. Summary Statistics in Print Layout (Mars Sjoden)
>   3. Re: Summary Statistics in Print Layout (matteo)
>   4. Import DWF in QGIS (manuela re)
>   5. What happened to "Update SQL Layer"? (Jonathan Schultz)
>   6. Re: What happened to "Update SQL Layer"? (Nicolas Boisteault)
>   7. Re: Trouble loading Grass in QGIS (learning thru the QGIS
>      training modules) (Andrea Giudiceandrea)
>   8. Re: Import DWF in QGIS (Nicolas Cadieux)
> Message: 1
> Date: Thu, 17 Mar 2022 12:48:50 -0700
> From: Dom O <dom225 at gmail.com>
> To: qgis-user at lists.osgeo.org
> Subject: [Qgis-user] Trouble loading Grass in QGIS (learning thru the
> 	QGIS training modules)
> Message-ID: <200253E8-DD53-43E9-ABD1-17BAB8BB5D5D at gmail.com>
> Content-Type: text/plain; charset="utf-8"
> Trouble loading Grass in QGIS (I?m learning thru the QGIS training modules)
> Getting this error when trying to begin GRASS in QGIS:
> "GRASS init error: Problem in GRASS initialization, GRASS provider and plugin will not work : Module built against version 2021-02-10T17:13:06+00:00 but trying to use version 2021-02-10T17:08:53+00:00. You need to rebuild GRASS GIS or untangle multiple installations."
> I've updated QGIS at least once in the past. Could this be the "multiple installation" issue?
> Do I simply delete the current QGIS version and reload a new one? What will happen to all the files I've already worked on?
> I?m running it on a MacBook and the modules have worked fine so far. Just this issue with GRASS.
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220317/335464a4/attachment-0001.html>
> A non-text attachment was scrubbed...
> Type: image/png
> Desc: not available
> URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220317/335464a4/attachment-0001.png>
> Message: 2
> Date: Thu, 17 Mar 2022 14:20:36 -0700
> From: Mars Sjoden <marsofearth at gmail.com>
> To: Qgis-user at lists.osgeo.org
> Subject: [Qgis-user] Summary Statistics in Print Layout
> Message-ID:
> 	<CAEKb5OndzGt3Ut5HCJmuy3MFVKpXyzeOh6qRX2wO8zSGiCV6Wg at mail.gmail.com>
> Hello,
> Is there a way to add summary statistics to print layout?
> Perhaps a work-a-round?
> Thank you.
> Mars
> URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220317/e3e777d7/attachment-0001.html>
> Message: 3
> Date: Fri, 18 Mar 2022 07:52:23 +0100
> From: matteo <matteo.ghetta at gmail.com>
> Subject: Re: [Qgis-user] Summary Statistics in Print Layout
> Message-ID: <f5c1d027-7c95-0782-ead6-fbc10ca05a5e at gmail.com>
> Content-Type: text/plain; charset=UTF-8; format=flowed
> Hi Mars,
> you can use the aggregate functions from the expression builder:
> https://docs.qgis.org/3.22/en/docs/user_manual/expressions/functions_list.html#aggregates-functions
> Cheers
> Matteo
> Message: 4
> Date: Fri, 18 Mar 2022 07:00:10 +0000 (UTC)
> From: manuela re <manuelalupina at yahoo.it>
> To: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
> Subject: [Qgis-user] Import DWF in QGIS
> Message-ID: <2039512847.72717.1647586810024 at mail.yahoo.com>
> I have to import a layer into qgis that surely has blocks but if I use the 'expand blocks' function qgis doesn't matter, it ignores it. how can I do?
> Thank's for help
> manuela?
> URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220318/8117a03c/attachment-0001.html>
> Message: 5
> Date: Fri, 18 Mar 2022 20:20:08 +0800
> From: Jonathan Schultz <jonathan at schultz.la>
> Subject: [Qgis-user] What happened to "Update SQL Layer"?
> Message-ID: <41b8dd20-df6a-9e96-adc3-1545ff20a977 at schultz.la>
> To answer my own question, I had a little discussion with the developers
> here: https://github.com/qgis/QGIS/pull/45801#issuecomment-1065101963
> and learned that the previous behaviour involved a silent (and
> irreversible) conversion of an PostGIS layer to a query layer. Now you
> have to explicitly create a query layer either using the DB manager or
> the browser.
> Message: 6
> Date: Fri, 18 Mar 2022 13:25:27 +0100
> From: Nicolas Boisteault <nboisteault at 3liz.com>
> Subject: Re: [Qgis-user] What happened to "Update SQL Layer"?
> Message-ID: <02efb153-3fbc-8b61-b16a-1f044a7d17b0 at 3liz.com>
> Content-Type: text/plain; charset="utf-8"; Format="flowed"
> Thanks for the tip!
> Le 18/03/2022 ? 13:20, Jonathan Schultz via Qgis-user a ?crit?:
>> developers here:
>> https://github.com/qgis/QGIS/pull/45801#issuecomment-1065101963 and
>> the browser.
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220318/a7df324d/attachment-0001.html>
> Message: 7
> Date: Fri, 18 Mar 2022 13:33:36 +0100
> From: Andrea Giudiceandrea <andreaerdna at libero.it>
> Subject: Re: [Qgis-user] Trouble loading Grass in QGIS (learning thru
> Message-ID: <da6ed6ed-2974-2dd2-e6bc-e173ab30ddb0 at libero.it>
>> *Dom O*dom225 at gmail.com
>> <mailto:qgis-user%40lists.osgeo.org?Subject=Re%3A%20%5BQgis-user%5D%20Trouble%20loading%20Grass%20in%20QGIS%20%28learning%20thru%20the%20QGIS%0A%20training%20modules%29&In-Reply-To=%3C200253E8-DD53-43E9-ABD1-17BAB8BB5D5D%40gmail.com%3E>
>> /Thu Mar 17 12:48:50 PDT 2022/
> Hi Dom O,
> what version of QGIS exactly are you using (look in the Help->About
> menu)? What installer have you used to install QGIS on the MacBook
> (there are "Official All-in-one" and "Alternative build" installers) and
> what version of macOS are you using?
> Please see the same "GRASS init error" already reported:
> https://github.com/qgis/QGIS-Mac-Packager/issues/120
> https://github.com/qgis/QGIS/issues/41782
> It seems this issue should only be about the "GRASS 7 plugin" and
> shouldn't affect the GRASS processing algorithm functionality. Do the
> GRASS processing algorithm works?
> Regards.
> Andrea
> URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220318/5022a526/attachment-0001.html>
> Message: 8
> Date: Fri, 18 Mar 2022 08:43:15 -0400
> From: Nicolas Cadieux <njacadieux.gitlab at gmail.com>
> To: manuela re <manuelalupina at yahoo.it>
> Cc: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] Import DWF in QGIS
> Message-ID: <F5725E73-6193-46AE-B34B-BBCBF76EE9B2 at gmail.com>
> Hi,
> Expand block should ?  transform the existing blocks into normal elements ?Is the block part of the drawing or could it be in an external reference?  An external reference is a separate file. You may possibly need this file.  It could help if you explained the steps you are using to import the file and your version of QGIS.  The version of the dwg would also help as QGIS is picky on the dwg file version.   If I recall, you can import a dwg as a file or under the project menu.  I would use the project menu.  If you have access to AutoCAD, change the file to a DXF.  An other option is to do that with FME. If it?s for a none commercial use, they have a ? free ? version made for learning.
> Nicolas Cadieux
> https://gitlab.com/njacadieux
>> Le 18 mars 2022 ? 03:00, manuela re via Qgis-user <qgis-user at lists.osgeo.org> a ?crit :
>> Thank's for help
>> manuela
> URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220318/a2f5f701/attachment-0001.html>
> Subject: Digest Footer
> End of Qgis-user Digest, Vol 193, Issue 43
