[Qgis-user] Qgis-user Digest, Vol 193, Issue 44
rayfson souza rayfson.fxsabedoria at gmail.com
Sat Mar 19 14:37:12 PDT 2022
I have a Samsung Galaxy Book with ARM processor running Windows 10. No qgis
installer works on this notebook. Is there an updated version of QGIS for
this processor and OS? I can't find a download for it.
Processor: Snapdragon (TM) 7c Gen 2 @.55GHz 2.55GHz
Ram: 4GB
64-bit operating system, ARM-based processor
Em sáb., 19 de mar. de 2022 às 15:01, <qgis-user-request at lists.osgeo.org>
escreveu:
> Send Qgis-user mailing list submissions to
>         qgis-user at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
>         https://lists.osgeo.org/mailman/listinfo/qgis-user
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         qgis-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Qgis-user digest..."
> Today's Topics:
>    1. Re: Qgis-user Digest, Vol 193, Issue 43 (Dom O)
>    2. Re: Qgis-user Digest, Vol 193, Issue 43 (Dom O)
>    3. Re: Summary Statistics in Print Layout (Mars Sjoden)
> Message: 1
> Date: Fri, 18 Mar 2022 14:48:21 -0700
> From: Dom O <dom225 at gmail.com>
> To: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] Qgis-user Digest, Vol 193, Issue 43
> Message-ID: <6FDEF4A0-0C59-4DB3-9973-A17DD1259985 at gmail.com>
> Content-Type: text/plain;       charset=utf-8
> Andrea thank you. MacOS is Big Sur 11.6.1, Qgis version is
> 3.22.4-Bia?owie?a direct from Qgis website, updated from an earlier
> version, which made me wonder if updating is causing the error. Perhaps I
> need to uninstall completely before installing the next version? I will
> look at thise 2 links you sent? Thanks!
> > On Mar 18, 2022, at 12:00 PM, qgis-user-request at lists.osgeo.org wrote:
> > Today's Topics:
> >   1. Trouble loading Grass in QGIS (learning thru the QGIS
> >      training modules) (Dom O)
> >   2. Summary Statistics in Print Layout (Mars Sjoden)
> >   3. Re: Summary Statistics in Print Layout (matteo)
> >   4. Import DWF in QGIS (manuela re)
> >   5. What happened to "Update SQL Layer"? (Jonathan Schultz)
> >   6. Re: What happened to "Update SQL Layer"? (Nicolas Boisteault)
> >   7. Re: Trouble loading Grass in QGIS (learning thru the QGIS
> >      training modules) (Andrea Giudiceandrea)
> >   8. Re: Import DWF in QGIS (Nicolas Cadieux)
> > Message: 1
> > Date: Thu, 17 Mar 2022 12:48:50 -0700
> > Subject: [Qgis-user] Trouble loading Grass in QGIS (learning thru the
> >       QGIS training modules)
> > Message-ID: <200253E8-DD53-43E9-ABD1-17BAB8BB5D5D at gmail.com>
> > Content-Type: text/plain; charset="utf-8"
> > Trouble loading Grass in QGIS (I?m learning thru the QGIS training
> modules)
> > Getting this error when trying to begin GRASS in QGIS:
> > "GRASS init error: Problem in GRASS initialization, GRASS provider and
> plugin will not work : Module built against version
> 2021-02-10T17:13:06+00:00 but trying to use version
> 2021-02-10T17:08:53+00:00. You need to rebuild GRASS GIS or untangle
> multiple installations."
> > I've updated QGIS at least once in the past. Could this be the "multiple
> installation" issue?
> > Do I simply delete the current QGIS version and reload a new one? What
> will happen to all the files I've already worked on?
> > I?m running it on a MacBook and the modules have worked fine so far.
> Just this issue with GRASS.
> > -------------- next part --------------
> > An HTML attachment was scrubbed...
> > URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20220317/335464a4/attachment-0001.html
> > A non-text attachment was scrubbed...
> > Type: image/png
> > Desc: not available
> > URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20220317/335464a4/attachment-0001.png
> > Message: 2
> > Date: Thu, 17 Mar 2022 14:20:36 -0700
> > From: Mars Sjoden <marsofearth at gmail.com>
> > To: Qgis-user at lists.osgeo.org
> > Subject: [Qgis-user] Summary Statistics in Print Layout
> > Message-ID:
> CAEKb5OndzGt3Ut5HCJmuy3MFVKpXyzeOh6qRX2wO8zSGiCV6Wg at mail.gmail.com>
> > Hello,
> > Is there a way to add summary statistics to print layout?
> > Perhaps a work-a-round?
> > Thank you.
> > Mars
> > URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20220317/e3e777d7/attachment-0001.html
> > Message: 3
> > Date: Fri, 18 Mar 2022 07:52:23 +0100
> > From: matteo <matteo.ghetta at gmail.com>
> > Subject: Re: [Qgis-user] Summary Statistics in Print Layout
> > Message-ID: <f5c1d027-7c95-0782-ead6-fbc10ca05a5e at gmail.com>
> > Content-Type: text/plain; charset=UTF-8; format=flowed
> > Hi Mars,
> > you can use the aggregate functions from the expression builder:
> https://docs.qgis.org/3.22/en/docs/user_manual/expressions/functions_list.html#aggregates-functions
> > Cheers
> > Matteo
> > Message: 4
> > Date: Fri, 18 Mar 2022 07:00:10 +0000 (UTC)
> > From: manuela re <manuelalupina at yahoo.it>
> > To: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
> > Subject: [Qgis-user] Import DWF in QGIS
> > Message-ID: <2039512847.72717.1647586810024 at mail.yahoo.com>
> > I have to import a layer into qgis that surely has blocks but if I use
> the 'expand blocks' function qgis doesn't matter, it ignores it. how can I
> do?
> > Thank's for help
> > manuela?
> > URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20220318/8117a03c/attachment-0001.html
> > Message: 5
> > Date: Fri, 18 Mar 2022 20:20:08 +0800
> > From: Jonathan Schultz <jonathan at schultz.la>
> > Subject: [Qgis-user] What happened to "Update SQL Layer"?
> > Message-ID: <41b8dd20-df6a-9e96-adc3-1545ff20a977 at schultz.la>
> > To answer my own question, I had a little discussion with the developers
> > here: https://github.com/qgis/QGIS/pull/45801#issuecomment-1065101963
> > and learned that the previous behaviour involved a silent (and
> > irreversible) conversion of an PostGIS layer to a query layer. Now you
> > have to explicitly create a query layer either using the DB manager or
> > the browser.
> > Message: 6
> > Date: Fri, 18 Mar 2022 13:25:27 +0100
> > From: Nicolas Boisteault <nboisteault at 3liz.com>
> > Subject: Re: [Qgis-user] What happened to "Update SQL Layer"?
> > Message-ID: <02efb153-3fbc-8b61-b16a-1f044a7d17b0 at 3liz.com>
> > Content-Type: text/plain; charset="utf-8"; Format="flowed"
> > Thanks for the tip!
> > Le 18/03/2022 ? 13:20, Jonathan Schultz via Qgis-user a ?crit?:
> >> developers here:
> >> https://github.com/qgis/QGIS/pull/45801#issuecomment-1065101963 and
> >> the browser.
> >> _______________________________________________
> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20220318/a7df324d/attachment-0001.html
> > Message: 7
> > Date: Fri, 18 Mar 2022 13:33:36 +0100
> > From: Andrea Giudiceandrea <andreaerdna at libero.it>
> > Subject: Re: [Qgis-user] Trouble loading Grass in QGIS (learning thru
> >       the QGIS training modules)
> > Message-ID: <da6ed6ed-2974-2dd2-e6bc-e173ab30ddb0 at libero.it>
> >> *Dom O*dom225 at gmail.com
> >> <mailto:qgis-user%40lists.osgeo.org
> ?Subject=Re%3A%20%5BQgis-user%5D%20Trouble%20loading%20Grass%20in%20QGIS%20%28learning%20thru%20the%20QGIS%0A%20training%20modules%29&In-Reply-To=%3C200253E8-DD53-43E9-ABD1-17BAB8BB5D5D%
> 40gmail.com%3E>
> >> /Thu Mar 17 12:48:50 PDT 2022/
> > Hi Dom O,
> > what version of QGIS exactly are you using (look in the Help->About
> > menu)? What installer have you used to install QGIS on the MacBook
> > (there are "Official All-in-one" and "Alternative build" installers) and
> > what version of macOS are you using?
> > Please see the same "GRASS init error" already reported:
> > https://github.com/qgis/QGIS-Mac-Packager/issues/120
> > https://github.com/qgis/QGIS/issues/41782
> > It seems this issue should only be about the "GRASS 7 plugin" and
> > shouldn't affect the GRASS processing algorithm functionality. Do the
> > GRASS processing algorithm works?
> > Regards.
> > Andrea
> > URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20220318/5022a526/attachment-0001.html
> > Message: 8
> > Date: Fri, 18 Mar 2022 08:43:15 -0400
> > From: Nicolas Cadieux <njacadieux.gitlab at gmail.com>
> > To: manuela re <manuelalupina at yahoo.it>
> > Cc: qgis-user at lists.osgeo.org
> > Subject: Re: [Qgis-user] Import DWF in QGIS
> > Message-ID: <F5725E73-6193-46AE-B34B-BBCBF76EE9B2 at gmail.com>
> > Hi,
> > Expand block should ?  transform the existing blocks into normal
> elements ?Is the block part of the drawing or could it be in an external
> reference?  An external reference is a separate file. You may possibly need
> this file.  It could help if you explained the steps you are using to
> import the file and your version of QGIS.  The version of the dwg would
> also help as QGIS is picky on the dwg file version.   If I recall, you can
> import a dwg as a file or under the project menu.  I would use the project
> menu.  If you have access to AutoCAD, change the file to a DXF.  An other
> option is to do that with FME. If it?s for a none commercial use, they have
> a ? free ? version made for learning.
> > Nicolas Cadieux
> > https://gitlab.com/njacadieux
> >> Le 18 mars 2022 ? 03:00, manuela re via Qgis-user <
> qgis-user at lists.osgeo.org> a ?crit :
> do?
> >> Thank's for help
> >> manuela
> > URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20220318/a2f5f701/attachment-0001.html
> > Subject: Digest Footer
> > End of Qgis-user Digest, Vol 193, Issue 43
> Message: 2
> Date: Fri, 18 Mar 2022 15:01:50 -0700
> Message-ID: <E6F087E0-4D85-45DD-9E9D-FF1CC20F406C at gmail.com>
> Content-Type: text/plain;       charset=us-ascii
> Andrea it looks like the problem is an abandoned/unmaintainedGRASS plugin
> and people are using the processing toolbox GRASS instead...
> > Today's Topics:
> > Message: 1
> modules)
> > URL: <
> > Type: image/png
> > Desc: not available
> > URL: <
> > Message: 2
> > Message-ID:
> > Hello,
> > Thank you.
> > Mars
> > URL: <
> > Message: 3
> > Hi Mars,
> > Cheers
> > Matteo
> > Message: 4
> do?
> > Thank's for help
> > manuela?
> > URL: <
> > Message: 5
> > the browser.
> > Message: 6
> > Thanks for the tip!
> >> developers here:
> >> the browser.
> > URL: <
> > Message: 7
> 40gmail.com%3E>
> > Hi Dom O,
> > Regards.
> > Andrea
> > URL: <
> > Message: 8
> > Hi,
> > Nicolas Cadieux
> do?
> >> Thank's for help
> >> manuela
> > URL: <
> Message: 3
> Date: Fri, 18 Mar 2022 15:27:01 -0700
> Message-ID:
>         <CAEKb5O=
> dkVWTycx_5QN7ZWtGf1qEEsMedc7zSCH8Wbu15OL4Rg at mail.gmail.com>
> Okay great nice to see it is possible.
> Are summary statistics in the future features for print layout?
> Mars
> On Thu, 17 Mar 2022 at 23:52, matteo via Qgis-user <
> qgis-user at lists.osgeo.org> wrote:
> > Hi Mars,
> > Cheers
> > Matteo
> URL: <
> http://lists.osgeo.org/pipermail/qgis-user/attachments/20220318/4aadd8f1/attachment-0001.html
> End of Qgis-user Digest, Vol 193, Issue 44
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220319/9175d232/attachment-0001.html>
