[Qgis-user] again: Create Geospatial PDF producing faulty output
Stewart Holt
stewartbholt at gmail.com
Mon Mar 21 09:01:30 PDT 2022
I had this problem recently on a project with a lot of layers. In the
dialog to produce the geo-PDF, there is a layer list. I found that some of
the layers which were checked in my project layer list were not checked in
this list (and maybe some checked which were not checked in my project).
After correcting this, I got the expected layers in my output. Also, in a
geo-PDF, there is a layer list which can be used to select which layers to
display while you are viewing it.
Stewart
On Mon, Mar 21, 2022 at 9:42 AM Uwe Fischer via Qgis-user <
qgis-user at lists.osgeo.org> wrote:
> Hello dear friends on the list,
> I’m sorry but I have to ask again about „Creating Geospatial PDF“ from the
> 3.22 Print Composer:
> does nobody have problems like missing features in the PDF output? The
> problem is very important for me, so any idea what the reason is would be
> appreciated. Not a single answer until now.
> The problem description: some features (in my case line features) are
> omitted when QGIS writes the geospatial PDF. Normal PDF output works fine,
> as well as TIF image output. So the problem cannot be in the data.
> Please help!
> Thanks, Uwe
> *Von:* Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] *Im Auftrag
> von *Uwe Fischer via Qgis-user
> *Gesendet:* Mittwoch, 16. März 2022 16:26
> *An:* qgis-user at lists.osgeo.org
> *Betreff:* [Qgis-user] Create Geospatial PDF producing faulty output
> Hello,
> when I chose „Create Geospatial PDF“ from the print composer in 3.22, I
> get a PDF with some missing vector lines. I can see no pattern or something
> like that in what features are skipped. „Normal“ PDF output (as well as
> TIF image output) is working fine. The setting for „Simplify vectors“ does
> not make a difference. Was the same error already in 3.18.
> Can anybody please tell me what is going wrong? Creating georeferenced
> PDFs with Layer structure is important to my current projects.
> And by the way: what is the difference between „Append georeference“ and
> „Create Geospatial“ in terms of geolocating?
> Thank you and regards, Uwe
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220321/78b22b08/attachment-0001.html>
