[Qgis-user] again: Create Geospatial PDF producing faulty output
Luciano Francisco da Silva
luciano.frco at hotmail.com
Mon Mar 21 09:17:56 PDT 2022
Ola poderia não mandar email p mim por favor
obrigado.
De: Qgis-user <qgis-user-bounces at lists.osgeo.org> em nome de Stewart Holt via Qgis-user <qgis-user at lists.osgeo.org>
Enviado: segunda-feira, 21 de março de 2022 13:01
Para: Uwe Fischer <gisfisch at t-online.de>
Cc: qgis-user <qgis-user at lists.osgeo.org>
Assunto: Re: [Qgis-user] again: Create Geospatial PDF producing faulty output
I had this problem recently on a project with a lot of layers. In the dialog to produce the geo-PDF, there is a layer list. I found that some of the layers which were checked in my project layer list were not checked in this list (and maybe some checked which were not checked in my project). After correcting this, I got the expected layers in my output. Also, in a geo-PDF, there is a layer list which can be used to select which layers to display while you are viewing it.
Stewart
On Mon, Mar 21, 2022 at 9:42 AM Uwe Fischer via Qgis-user <qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>> wrote:
Hello dear friends on the list,
I’m sorry but I have to ask again about „Creating Geospatial PDF“ from the 3.22 Print Composer:
does nobody have problems like missing features in the PDF output? The problem is very important for me, so any idea what the reason is would be appreciated. Not a single answer until now.
The problem description: some features (in my case line features) are omitted when QGIS writes the geospatial PDF. Normal PDF output works fine, as well as TIF image output. So the problem cannot be in the data.
Please help!
Thanks, Uwe
Von: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org<mailto:qgis-user-bounces at lists.osgeo.org>] Im Auftrag von Uwe Fischer via Qgis-user
Gesendet: Mittwoch, 16. März 2022 16:26
An: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
Betreff: [Qgis-user] Create Geospatial PDF producing faulty output
Hello,
when I chose „Create Geospatial PDF“ from the print composer in 3.22, I get a PDF with some missing vector lines. I can see no pattern or something like that in what features are skipped. „Normal“ PDF output (as well as TIF image output) is working fine. The setting for „Simplify vectors“ does not make a difference. Was the same error already in 3.18.
Can anybody please tell me what is going wrong? Creating georeferenced PDFs with Layer structure is important to my current projects.
And by the way: what is the difference between „Append georeference“ and „Create Geospatial“ in terms of geolocating?
Thank you and regards, Uwe
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220321/51250b6f/attachment.html>
