[Qgis-user] SAGA Strahler Order
Klaus Mithöfer mithoefer at gbd-consult.de
Wed Nov 2 05:58:01 PDT 2022
Hi Nicolas,
do you use SAGA through QGIS toolbox? The message you might get there
means that QGIS does not support the SAGA Version and it might not work.
You better rung the process in SAGA.
You can download the latest SAGA version for Windows here:
https://sourceforge.net/projects/saga-gis/files/ its already Version 8.x
for Windows. Just run the algorithm in SAGA directly.
Kind regards, Klaus
Am 02.11.22 um 12:51 schrieb Nicolas Cadieux via Qgis-user:
> Hi,
> I have not looked at saga lately but I am surprised to see it’s not
> supported in windows?!  I would use any other window version of Saga as
> I don’t think that algorithms has changed much.  The other option is to
> install Saga using Ubuntu in WSL.  You can download that in the Windows
> App Store.
> Nicolas Cadieux
> https://gitlab.com/njacadieux <https://gitlab.com/njacadieux>
>> Le 17 oct. 2022 à 05:28, Adamu El-Oji via Qgis-user
>> <qgis-user at lists.osgeo.org> a écrit :
>> Hi everyone
>> I trying do water delineation  and Strahler Order plugin constant error
>> SAGA 7.2.8 not support for windows
>> Is there any option to that?
>> Thanks
>> Adamu El-Oji
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
