[Qgis-user] SAGA Strahler Order
Nicolas Cadieux njacadieux.gitlab at gmail.com
Wed Nov 2 07:31:09 PDT 2022
I normally don’t use the toolbox as it seems to have trouble saving saga rasters. This is a problem when saving the grid file then using them in another Saga process.  If I use the temporary files, then, all is good.  I have also worked a bit with the saga next gen plugin but Saga is pretty easy to use so I mostly go straight to Saga.
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 2 nov. 2022 à 09:07, Klaus Mithöfer via Qgis-user <qgis-user at lists.osgeo.org> a écrit :
> Hi Nicolas,
> do you use SAGA through QGIS toolbox? The message you might get there means that QGIS does not support the SAGA Version and it might not work. You better rung the process in SAGA.
> You can download the latest SAGA version for Windows here: https://sourceforge.net/projects/saga-gis/files/ its already Version 8.x for Windows. Just run the algorithm in SAGA directly.
> Kind regards, Klaus
>> Am 02.11.22 um 12:51 schrieb Nicolas Cadieux via Qgis-user:
>> Hi,
>> I have not looked at saga lately but I am surprised to see it’s not supported in windows?!  I would use any other window version of Saga as I don’t think that algorithms has changed much.  The other option is to install Saga using Ubuntu in WSL.  You can download that in the Windows App Store.
>> Nicolas Cadieux
>> https://gitlab.com/njacadieux <https://gitlab.com/njacadieux>
>>>> Le 17 oct. 2022 à 05:28, Adamu El-Oji via Qgis-user <qgis-user at lists.osgeo.org> a écrit :
>>> Hi everyone
>>> I trying do water delineation  and Strahler Order plugin constant error
>>> SAGA 7.2.8 not support for windows
>>> Is there any option to that?
>>> Thanks
>>> Adamu El-Oji
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20221102/17c3c8f7/attachment.htm>
