[Qgis-user] query for Virtual Layer in relation to another layer
Jürgen E. Fischer jef at norbit.de
Fri Nov 4 05:15:34 PDT 2022
On Fri, 04. Nov 2022 at 12:32:29 +0100, Uwe Fischer via Qgis-user wrote:
> On Montag, 24. Oktober 2022 15:32, Reetz, Michael (NLPV) wrote:
> > you could try this:
> > select * from my_lines l join my_polys p on l.my_line_attribute like '%' + p.my_poly_attribute + '%'
> sorry for the delay, I had some days out of office.
> The query you sent is working (that is: no error message), but the resulting virtual layer is empty. Are there other ideas?
Not sure which engine virtual layers actually use, but I'd try || instead of +
As in
sqlite> select '%' || 'foo' || '%';
%foo%
instead of
sqlite> select '%' + 'foo' + '%';
0
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden            https://www.norbit.de
QGIS release manager (PSC)  Germany                 IRC: jef on Libera|OFTC
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20221104/bc4bbf18/attachment.sig>
