[Qgis-user] query for Virtual Layer in relation to another layer
Uwe Fischer gisfisch at t-online.de
Fri Nov 4 05:59:35 PDT 2022
Jürgen,
great - it works as expected!! Thank you!
How can I find out about the engine that is used and the SQL syntax for virtual layers? I'd like to learn about it to be able to build more queries like this one.
Thanks again and best regards,
Uwe
Jürgen wrote:
Not sure which engine virtual layers actually use, but I'd try || instead of +
As in
sqlite> select '%' || 'foo' || '%';
%foo%
instead of
sqlite> select '%' + 'foo' + '%';
0
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden            https://www.norbit.de
QGIS release manager (PSC)  Germany                 IRC: jef on Libera|OFTC
