[Qgis-user] Opening a layout in "Zoom full" view
Nicolas Cadieux njacadieux.gitlab at gmail.com
Tue Nov 8 08:24:06 PST 2022
Just tested on 3.26.3 on a brand new install (Windows 11 and all).  I
confirm that this is a problem.  I would do a bug report. This should
not be an option. Layout opens at 5.7% even when saved at 100%.
Nicolas
Le 2022-11-02 à 4:42 p.m., Tony Shepherd (FarmMaps NZ) a écrit :
> Hi Nicolas
> Yes, I too had those issues with MapInfo and AutoCAD in a previous
> life.  This is a stock standard QGIS layout, just a normal A4 and A3
> layout, both either portrait or landscape.
> Any saved project, or any new project.  Add a layout or two that
> contain the normal layout elements (map window(s), scale bars, free
> text, attribute table etc).  All elements are within the “page”. Close
> everything, open that saved project file, open the layout or layouts,
> and the first view you get of that layout is a small view (say 20% or
> so).  Then press the View Extents button and then it zooms to the
> extent as expected.  So that tells me if there was an element placed
> in a strange place within the layout then zooming to the extents would
> then make that rogue element obvious, so in my case, I am sure that is
> not the reason.
> I think it would be a good feature that when saving a project, the
> layout will open at the same view scale as when the project was saved,
> or perhaps have a flag that allows you to set a default layout zoom scale.
> It seems to me that in V3.26, when using any project file old or new,
> the layouts seem to open at a much smaller zoom scale than previous
> version.
> Cheers
> Tony
> *Tony Shepherd**|*  GeoSpatial / Mapping Manager
> *Ph*027 435 6193 *|**E* tony at farmmaps.nz <mailto:tony at farmmaps.nz>
> *|**W* shepherdphotos.co.nz <http://shepherdphotos.co.nz/>
> FM_logo1_small (Custom)
> <https://www.wunderground.com/personal-weather-station/dashboard?ID=ISTLGORE2>**
> Cheers
> Tony
> *From:*Nicolas Cadieux <njacadieux.gitlab at gmail.com>
> *Sent:* Thursday, 3 November 2022 1:30 am
> *To:* Tony Shepherd (FarmMaps NZ) <tony at farmmaps.nz>
> *Cc:* Qgis Users List <qgis-user at lists.osgeo.org>
> *Subject:* Re: [Qgis-user] Opening a layout in "Zoom full" view
> Hi,
> I have not experienced this yet in QGIS.  Is it in all of your
> projects or just one?  It could be related to a certain file.  In the
> past, I have had this problem with AutoCAD and Mapinfo.  It was
> usually related to a file having  objects around the 0,0 coordinate,
> (way off the normal coordinate system of the file).  Have you checked
> the individual file extents?
> Nicolas Cadieux
> https://gitlab.com/njacadieux
>     Le 1 nov. 2022 à 16:08, Tony Shepherd (FarmMaps NZ) via Qgis-user
>     <qgis-user at lists.osgeo.org> a écrit :
>     Hi All
>     Maybe a silly question, but not one that I could easily find an
>     answer to.
>     Is there a way to set QGIS so that when it opens an existing
>     layout that it automatically displays it in “Zoom full” mode or
>     maybe set a flag somewhere that when you save the project the
>     current layout zoom is retained so that on re-opening it pops back
>     to how it was last displayed?
>     V3.26 seems to behave so that whenever I open a previously saved
>     layout it is about the size of a postage stamp and I have to press
>     the “Zoom full” button, regardless of how I last saved it.
>     Thoughts?
>     Cheers
>     Tony
>     <image001.jpg>
>     *<image002.png><https://www.wunderground.com/personal-weather-station/dashboard?ID=ISTLGORE2>*
>     _______________________________________________
>     Qgis-user mailing list
>     Qgis-user at lists.osgeo.org
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20221108/6d0b55c1/attachment.htm>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20221108/6d0b55c1/attachment.jpg>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20221108/6d0b55c1/attachment.png>
