[Qgis-user] multiple csv file import
Salvatore Mellino salvatore.mellino at prismambiente.it
Tue Nov 15 08:59:37 PST 2022
Hello,
thank you for your answer. I have many csv (about 100), so I need an
automatic procedure. Maybe a python script...
Il 15/11/2022 16:55, Nicolas Cadieux ha scritto:
> Hi,
> Yes, you can do that very easily using QGIS.  Layer/add layer/add
> delimited text layer.  Then just export the layer in the format of
> your choice. You may need to convert the coordinates in decimal
> degrees (ex 75 05 30.4 -> 75.0917777777778000000 ).
> You can do this in Excel using =(A6)+(B6/60)+(C6/3600)+(D6/3600) A=
> Deg, B= Min, C=Sec, D= Decimal Sec.  Then export to csv.
> Nicolas
> On 2022-11-15 10:08 a.m., Salvatore Mellino via Qgis-user wrote:
>> Hello,
>> I would like to know if it is possible to import multiple csv files
>> contained in a folder and to convert them in shapefiles (1 for each
>> csv). All csv files are structured as "lat long value" separate by
>> space and without any header line.
>> Thank you for your help! Regards,
>> Salvatore
Salvatore Mellino
Dottore di Ricerca/Ph.D.
Prisma s.r.l. - Progettazione e Realizzazione Impianti e Servizi di Monitoraggio Ambientale
Via Monsignor Bonaventura Gargiulo, 13 - 80065 S.Agnello (NA)
Tel./Fax: +39 081 8072476
www.prismambiente.it
