[Qgis-user] multiple csv file import
Nicolas Cadieux njacadieux.gitlab at gmail.com
Tue Nov 15 08:55:45 PST 2022
Yes, you can do that very easily using QGIS.  Layer/add layer/add
delimited text layer.  Then just export the layer in the format of your
choice. You may need to convert the coordinates in decimal degrees (ex
75 05 30.4 -> 75.0917777777778000000 ).
You can do this in Excel using =(A6)+(B6/60)+(C6/3600)+(D6/3600) A= Deg,
B= Min, C=Sec, D= Decimal Sec.  Then export to csv.
Nicolas
On 2022-11-15 10:08 a.m., Salvatore Mellino via Qgis-user wrote:
> Hello,
> I would like to know if it is possible to import multiple csv files
> contained in a folder and to convert them in shapefiles (1 for each
> csv). All csv files are structured as "lat long value" separate by
> space and without any header line.
> Thank you for your help! Regards,
> Salvatore
Nicolas Cadieux
https://gitlab.com/njacadieux
