[Qgis-user] laz filename to copc.laz
Javier Jimenez Shaw j1 at jimenezshaw.com
Thu Nov 24 08:16:10 PST 2022
Hi
I just opened a LAZ file name "Stadium_1.38.0-area_point_cloud.laz" that
created a copy called "Stadium_1.copc.laz"
It is cool, because it produces a responsive visualization.
However I was expecting the created file to be named
"Stadium_1.38.0-area_point_cloud.copc.laz" or even
"Stadium_1.38.0-area_point_cloud.laz.copc" (somehow like sidecar files in
GDAL - ovr, aux.xml - that only add characters, but do not change the root
name). Removing part of the filename (everything after the first dot) could
be problematic...
Actually I cannot see the file Stadium_1.38.1-area_point_cloud.laz. I have
to rename to something different at the beginning, before the first dot.
Cheers,
Javier.
.___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20221124/c59ea6e5/attachment.htm>
