[Qgis-user] Missing python plugin support on Win7
Richard Duivenvoorde rdmailings at duif.net
Fri Nov 25 02:19:07 PST 2022
WIndows dropped support for the latest python versions.
Or de other way around, Python did not support Windows 7 anymore, I forgot.
Anyway, you will not be able to run the latest version of QGIS on a Win7 machine. Because QGIS depends on a newer Python version then will run on your Win7 machine.
You can download an older QGIS version (3.14 if I'm correct) which contains a Python which is working on Win7.
Or: try to upgrade to Windows 10
Or: install Ubuntu on your machine ( <= my preferred solution ;-) )
Regards,
On 11/25/22 08:07, Antonio Valanzano via Qgis-user wrote:
> I have used the latest osgeo4w-setup.exe (which includes the patch for Win7)  on a pc with Win7 and I have installed QGIS 3.22.13-Białowieża.
> It starts but when I try to install a plugin I do not see a list of available plugins and in the "settings" tab there is this message
> So in Win7 is not possible to use any plugin apart from these 3
> Is there a way to activate the Python support choosing some options in the setup program ?
> I have accepted all the default options during the installation.
> Antonio
> Qgis-user mailing list
