[Qgis-user] Exporting QGIS to AutoCAD DXF in Metric Units
Nicolas Cadieux njacadieux.gitlab at gmail.com
Mon Oct 3 12:53:56 PDT 2022
DXF file, to my knowledge have no unit information.  Unit is defined in
AutoCad.  Various version of AutoCad have their own way of doing this.
EPSG 26917 is in meters therefore the export unit will be meters.
Nicolas
On 2022-10-03 3:13 p.m., Wong, Gordon via Qgis-user wrote:
> Hi QGIS team,
> I am currently using QGIS 3.16.16. My data are typically represented
> by contours and they are in metres. I always use the coordinate system
> EPSG 26917 for my work. However, whenever I export the contours using
> the “Save Feature As” function on QGIS to an AutoCAD DXF file. The
> default DXF file is in feet and I have to manually change the units on
> AutoCAD to metric. The scaling of the contours is correct in AutoCAD
> though. Is there any way to make sure the exported DXF is in metric units?
> Thank you very much for the help!
> Sincerely,
>         Gordon
> NOTICE: This communication and any attachments ("this message") may
> contain information which is privileged, confidential, proprietary or
> otherwise subject to restricted disclosure under applicable law. This
> message is for the sole use of the intended recipient(s). Any
> unauthorized use, disclosure, viewing, copying, alteration,
> dissemination or distribution of, or reliance on, this message is
> strictly prohibited. If you have received this message in error, or
> you are not an authorized or intended recipient, please notify the
> sender immediately by replying to this message, delete this message
> and all copies from your e-mail system and destroy any printed copies.
> You are receiving this communication because you are listed as a
> current WSP contact. Should you have any questions regarding WSP's
> electronic communications policy, please consult our Anti-Spam
> Commitment at www.wsp.com/casl <http://www.wsp.com/casl>. For any
> concern or if you believe you should not be receiving this message,
> please forward this message to caslcompliance at wsp.com so that we can
> promptly address your request. Note that not all messages sent by WSP
> qualify as commercial electronic messages.
> AVIS : Ce message, incluant tout fichier l'accompagnant (« le message
> »), peut contenir des renseignements ou de l'information privilégiés,
> confidentiels, propriétaires ou à divulgation restreinte en vertu de
> la loi. Ce message est destiné à l'usage exclusif du/des
> destinataire(s) voulu(s). Toute utilisation non permise, divulgation,
> lecture, reproduction, modification, diffusion ou distribution est
> interdite. Si vous avez reçu ce message par erreur, ou que vous n'êtes
> pas un destinataire autorisé ou voulu, veuillez en aviser l'expéditeur
> immédiatement et détruire le message et toute copie électronique ou
> imprimée. Vous recevez cette communication car vous faites partie des
> contacts de WSP. Si vous avez des questions concernant la politique de
> communications électroniques de WSP, veuillez consulter notre
> Engagement anti-pourriel au www.wsp.com/lcap
> <http://www.wsp.com/lcap>. Pour toute question ou si vous croyez que
> vous ne devriez pas recevoir ce message, prière de le transférer au
> conformitelcap at wsp.com afin que nous puissions rapidement traiter
> votre demande. Notez que ce ne sont pas tous les messages transmis par
> WSP qui constituent des messages electroniques commerciaux.
> -LAEmHhHzdJzBlTWfa4Hgs7pbKl
> Qgis-user mailing list
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
Nicolas Cadieux
https://gitlab.com/njacadieux
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20221003/7c595f4a/attachment.htm>
