[Qgis-user] Exporting QGIS to AutoCAD DXF in Metric Units
Andrea Giudiceandrea andreaerdna at libero.it
Mon Oct 3 13:17:12 PDT 2022
> *Wong, Gordon*Gordon.Wong1 at wsp.com
> <mailto:qgis-user%40lists.osgeo.org?Subject=Re%3A%20%5BQgis-user%5D%20Exporting%20QGIS%20to%20AutoCAD%20DXF%20in%20Metric%20Units&In-Reply-To=%3CDB8PR05MB669877582184539A42358E06D05B9%40DB8PR05MB6698.eurprd05.prod.outlook.com%3E>
> /Mon Oct 3 12:13:54 PDT 2022/
> I am currently using QGIS 3.16.16. My data are typically represented by contours and they are in metres. I always use the coordinate system EPSG 26917 for my work. However, whenever I export the contours using the "Save Feature As" function on QGIS to an AutoCAD DXF file. The default DXF file is in feet and I have to manually change the units on AutoCAD to metric.
Hi Gordon,
it is a known issue: please see [1] and [2] for reference and workaround.
Best regards.
[1] https://gdal.org/drivers/vector/dxf.html#units
[2]
https://gis.stackexchange.com/questions/349048/export-vector-layer-in-dxf-with-systematically-metrical-system-unit
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20221003/dbca029d/attachment.htm>
