[Qgis-user] Exporting QGIS to AutoCAD DXF in Metric Units
Wong, Gordon Gordon.Wong1 at wsp.com
Mon Oct 3 13:40:53 PDT 2022
Hi Andrea,
Thank you! It works!
Sincerely,
               Gordon
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of Andrea Giudiceandrea via Qgis-user
Sent: October 3, 2022 4:17 PM
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Exporting QGIS to AutoCAD DXF in Metric Units
Wong, Gordon Gordon.Wong1 at wsp.com<mailto:qgis-user%40lists.osgeo.org?Subject=Re%3A%20%5BQgis-user%5D%20Exporting%20QGIS%20to%20AutoCAD%20DXF%20in%20Metric%20Units&In-Reply-To=%3CDB8PR05MB669877582184539A42358E06D05B9%40DB8PR05MB6698.eurprd05.prod.outlook.com%3E>
Mon Oct 3 12:13:54 PDT 2022
I am currently using QGIS 3.16.16. My data are typically represented by contours and they are in metres. I always use the coordinate system EPSG 26917 for my work. However, whenever I export the contours using the "Save Feature As" function on QGIS to an AutoCAD DXF file. The default DXF file is in feet and I have to manually change the units on AutoCAD to metric.
Hi Gordon,
it is a known issue: please see [1] and [2] for reference and workaround.
Best regards.
[1] https://gdal.org/drivers/vector/dxf.html#units
[2] https://gis.stackexchange.com/questions/349048/export-vector-layer-in-dxf-with-systematically-metrical-system-unit
NOTICE: This communication and any attachments ("this message") may contain information which is privileged, confidential, proprietary or otherwise subject to restricted disclosure under applicable law. This message is for the sole use of the intended recipient(s). Any unauthorized use, disclosure, viewing, copying, alteration, dissemination or distribution of, or reliance on, this message is strictly prohibited. If you have received this message in error, or you are not an authorized or intended recipient, please notify the sender immediately by replying to this message, delete this message and all copies from your e-mail system and destroy any printed copies. You are receiving this communication because you are listed as a current WSP contact. Should you have any questions regarding WSP's electronic communications policy, please consult our Anti-Spam Commitment at www.wsp.com/casl<http://www.wsp.com/casl>. For any concern or if you believe you should not be receiving this message, please forward this message to caslcompliance at wsp.com<mailto:caslcompliance at wsp.com> so that we can promptly address your request. Note that not all messages sent by WSP qualify as commercial electronic messages.
AVIS : Ce message, incluant tout fichier l'accompagnant (« le message »), peut contenir des renseignements ou de l'information privilégiés, confidentiels, propriétaires ou à divulgation restreinte en vertu de la loi. Ce message est destiné à l'usage exclusif du/des destinataire(s) voulu(s). Toute utilisation non permise, divulgation, lecture, reproduction, modification, diffusion ou distribution est interdite. Si vous avez reçu ce message par erreur, ou que vous n'êtes pas un destinataire autorisé ou voulu, veuillez en aviser l'expéditeur immédiatement et détruire le message et toute copie électronique ou imprimée. Vous recevez cette communication car vous faites partie des contacts de WSP. Si vous avez des questions concernant la politique de communications électroniques de WSP, veuillez consulter notre Engagement anti-pourriel au www.wsp.com/lcap<http://www.wsp.com/lcap>. Pour toute question ou si vous croyez que vous ne devriez pas recevoir ce message, prière de le transférer au conformitelcap at wsp.com<mailto:conformitelcap at wsp.com> afin que nous puissions rapidement traiter votre demande. Notez que ce ne sont pas tous les messages transmis par WSP qui constituent des messages electroniques commerciaux.
-LAEmHhHzdJzBlTWfa4Hgs7pbKl
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20221003/a2f0c13b/attachment-0001.htm>
