[Qgis-user] graduated symbology classes update
Hugh Kelley hghklly at gmail.com
Thu Oct 20 08:57:43 PDT 2022
oops here's the image.
https://imgur.com/a/cKBIRSF
On Thu, Oct 20, 2022 at 11:53 AM Hugh Kelley <hghklly at gmail.com> wrote:
> Hi all,
> Just wondering if anyone has a fix for a minor annoyance.
> When using graduated symbology, if I want to change the number of classes
> from the default 5 to something else, there's an easy field to update. If
> I'm changing it to a double digit number, or changing a double digit number
> to a different double digit number, the number of classes is updated as
> soon as I make the first key stroke.
> for example to turn 10 into 15, QGIS calculates 10 -> 1 -> 15.
> I can turn off automatic updating of the map which saves some time, but it
> still needs to calculate the class breaks.
> Just wondering whether there's a fix I'm not seeing or whether it's worth
> logging an issue about.
> This is on 3.22.
> image of the graduated symbology interface in case it clarifies what I'm
> talking about.
> thanks
> Hugh
Hugh Kelley
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20221020/847e5de2/attachment.htm>
