[Qgis-user] Georeferencer issue
Andrea Giudiceandrea
andreaerdna at libero.it
Thu Oct 20 14:15:30 PDT 2022
> *Lester Anderson*
> /Thu Oct 20 08:55:50 PDT 2022/
> I have been trying to georeference a ~20Mb image but it will not process to
> completion, progress stalls at 4%. Is there a size limit for a file? Or is
> this a bug?
> QGIS 3.24.3 Tisler
Hi Lester.
QGIS 3.24 is an old version no longer supported.
Anyway, have you tried if the georeferencing procedure also fails using
a new QGIS user profile?
What are the properties of the the image to georeference (dimension in
pixels, resolution, extent, CRS) and what are the Georeferencer option
used for the output?
Could you share the image file, the GCPs and the georeferencing option
used, in order to check if the issue also occurs on other systems?
Best regards.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20221020/1ee4ddd6/attachment.htm>
