[Qgis-user] Georeferencer issue
Lester Anderson
arctica1963 at gmail.com
Fri Oct 21 08:00:17 PDT 2022
Hello Andrea,
I created a new user profile and the georeferencer worked fine. Not sure
what was wrong with the default profile!
I guess there must be some configuration issue in the default profile.
Anyway, seems to be ok now.
Lester
On Thu, 20 Oct 2022 at 22:15, Andrea Giudiceandrea via Qgis-user <
qgis-user at lists.osgeo.org> wrote:
> *Lester Anderson*
> *Thu Oct 20 08:55:50 PDT 2022*
> I have been trying to georeference a ~20Mb image but it will not process to
> completion, progress stalls at 4%. Is there a size limit for a file? Or is
> this a bug?
> QGIS 3.24.3 Tisler
> Hi Lester.
> QGIS 3.24 is an old version no longer supported.
> Anyway, have you tried if the georeferencing procedure also fails using a
> new QGIS user profile?
> What are the properties of the the image to georeference (dimension in
> pixels, resolution, extent, CRS) and what are the Georeferencer option used
> for the output?
> Could you share the image file, the GCPs and the georeferencing option
> used, in order to check if the issue also occurs on other systems?
> Best regards.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20221021/4b27cc39/attachment.htm>
