[Qgis-user] Coordinate display in different coordinate systems
C Hamilton
adenaculture at gmail.com
Fri Oct 28 08:30:02 PDT 2022
The Lat Lon Tools plugin has a coordinate display dialog where you click on
a point and it displays it in many different coordinate systems.
On Fri, Oct 28, 2022 at 9:30 AM Tanja Hartinger via Qgis-user <
qgis-user at lists.osgeo.org> wrote:
> Hello
> I have a question about the coordinate display. Is it possible that I
> can display the coordinates in several coordinate systems (I am in
> Germany and therefore in my case it is about the coordinate systems
> Gauß-Krüger and UTM) somewhere on a map at the same time? I don't want
> to set an object there. Ideally, I click somewhere and then the
> coordinates are displayed in several coordinate systems. Is this
> possible in any way?
> Thank you very much in advance.
> Many greetings,
> Tanja
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20221028/c2ed8372/attachment.htm>
