[Qgis-user] Coordinate display in different coordinate systems
Richard Duivenvoorde
rdmailings at duif.net
Fri Oct 28 06:43:39 PDT 2022
Right-click in the mapcanvas shows you 'Copy coordinates', with the crs's which are in your project (I think).
You can also add a custom crs.
It shows them, AND you can copy one of them.
That is not what you want?
Regards,
On 10/28/22 15:30, Tanja Hartinger via Qgis-user wrote:
> Hello
> I have a question about the coordinate display. Is it possible that I
> can display the coordinates in several coordinate systems (I am in
> Germany and therefore in my case it is about the coordinate systems
> Gauß-Krüger and UTM) somewhere on a map at the same time? I don't want
> to set an object there. Ideally, I click somewhere and then the
> coordinates are displayed in several coordinate systems. Is this
> possible in any way?
> Thank you very much in advance.
> Many greetings,
> Tanja
> Qgis-user mailing list
