[Qgis-user] Faster Intersects
Alexandre Neto senhor.neto at gmail.com
Fri Sep 9 10:19:30 PDT 2022
Following raymond advice,
Move the CSV to a shapefile or geopackage and run the create spatial index
on it.
If you have very complex polygons, use suvdivide to create smaller ones
save it in shapefile or geopackage and run create spatial index on it.
https://docs.qgis.org/3.22/en/docs/user_manual/processing_algs/qgis/vectorgeometry.html#subdivide
I would try with a smaller subset of points to test the improvement speed
before trying to run on the full dataset again.
Answering your question, yes I am pretty sure postgis is much faster than
mssql, and yes I think most recent versions of PostgreSQL PostGIS make use
of more than one core.
Good luck
A sexta, 9/09/2022, 17:59, Dennis Burgess via Qgis-user <
qgis-user at lists.osgeo.org> escreveu:
> In the format, are you talking about the shape or the CSV with 2million
> lines?
> Dennis Burgess
> Author of "Learn RouterOS- Second Edition”
> Link Technologies, Inc -- Mikrotik & WISP Support Services
> Office: 314-735-0270  Website: http://www.linktechs.net
> Create Wireless Coverage’s with www.towercoverage.com
> Need MikroTik Cloud Management: https://cloud.linktechs.net
> -----Original Message-----
> From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of Raymond
> Nijssen via Qgis-user
> Sent: Friday, September 9, 2022 11:11 AM
> To: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] Faster Intersects
> Some things to check:
> * Is your data local?
> * Is it in a fast file format? (for example .gpkg or .shp and not .csv or
> .geojson)
> * Does the data have a spatial index?
> * Is the geometry very complicated, like a huge multi polygon with
> thousands of vertices and islands? In that case, split it up in several
> polygons.
> Hope this helps. Anyway, it should not need to take this long.
> Raymond
> On 09-09-2022 16:28, Dennis Burgess via Qgis-user wrote:
> > How can I speed up Intersects?  Right now I have a single geometry
> > file, but then have about 2 million points that I need to understand
> > what intersects that geometry.  Right now its taking 3 days?
> > QGIS-bin.exe is only using 11% CPU.. ☹
> > Dennis
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220909/7d53c896/attachment.htm>
