[Qgis-user] GDAL problem
boxerg at iinet.net.au boxerg at iinet.net.au
Fri Sep 9 20:26:53 PDT 2022
Hi all, when I try to pansharpen an image using gdal, I get the following
message. Any thoughts?
QGIS version: 3.26.2-Buenos Aires
QGIS code revision: feec3d3b
Qt version: 5.15.3
Python version: 3.9.5
GDAL version: 3.5.1
GEOS version: 3.10.3-CAPI-1.16.1
PROJ version: Rel. 9.1.0, September 1st, 2022
PDAL version: 2.4.3 (git-version: 6311a6)
Algorithm started at: 2022-09-10T11:24:16
Algorithm 'Pansharpening' starting.
Input parameters:
{ 'EXTRA' : '', 'OPTIONS' : '', 'OUTPUT' :
'D:/Projects/REE/PRS_L2D_STD_20210502012240_20210502012244_0001/SWIR_Panshar
pened.vrt', 'PANCHROMATIC' :
'D:/Projects/REE/PRS_L2D_STD_20210502012240_20210502012244_0001/NolansBore_S
pectraCube_SWIR.tif', 'RESAMPLING' : 2, 'SPECTRAL' :
pectraCube_SWIR.tif' }
GDAL command:
gdal_pansharpen.bat
D:\Projects\REE\PRS_L2D_STD_20210502012240_20210502012244_0001\NolansBore_Sp
ectraCube_SWIR.tif
ectraCube_SWIR.tif
D:/Projects/REE/PRS_L2D_STD_20210502012240_20210502012244_0001/SWIR_Pansharp
ened.vrt -r cubic -of VRT
GDAL command output:
Process gdal_pansharpen.bat failed to start. Either gdal_pansharpen.bat is
missing, or you may have insufficient permissions to run the program.
Execution failed after 0.17 seconds
Loading resulting layers
Algorithm 'Pansharpening' finished
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220910/19d9aa87/attachment.htm>
