[Qgis-user] GDAL problem
Andrea Giudiceandrea andreaerdna at libero.it
Fri Sep 9 23:24:21 PDT 2022
> *boxerg at iinet.net.au*boxerg at iinet.net.au
> <mailto:qgis-user%40lists.osgeo.org?Subject=Re%3A%20%5BQgis-user%5D%20GDAL%20problem&In-Reply-To=%3C13ab01d8c4c5%242c10ce90%2484326bb0%24%40iinet.net.au%3E>
> /Fri Sep 9 20:26:53 PDT 2022/
> Hi all, when I try to pansharpen an image using gdal, I get the following
> message.
> Process gdal_pansharpen.bat failed to start. Either gdal_pansharpen.bat is
> missing, or you may have insufficient permissions to run the program.
Hi boxerg,
what is your operative system exactly? Is the gdal_pansharpen.bat file
available in your QGIS_install_dir\apps\Python39\Scripts\ folder? Have
you tried to run the command in the OSGeo4W Shell? What errors are
displayed, if any?
Best regards.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20220910/01faebe1/attachment.htm>
