[Qgis-user] Oriented Minimum Bounding Box
Andrea Giudiceandrea andreaerdna at libero.it
Fri Sep 16 15:19:42 PDT 2022
Hi Jon,
I apologize, but I think I don't understand exactly what the problem is.
Anyway, if you need a unique "Oriented Minimum Bounding Box" that
encloses all the features in the layer, then - as you probably already
found - you can use the "Minimum bounding geometry" processing algorithm
specifying the "Minimum Oriented Rectangle" method in the "Geometry
type" parameter and without specifying any field in the "Field" parameter.
Regards.
Andrea
