[Qgis-user] Oriented Minimum Bounding Box
Jon
jonr at destar.net
Fri Sep 16 18:09:56 PDT 2022
Yes, you are correct. That is what I found as well and tried to explain
in my last email.
Thank you for taking the time to respond and help me progress a little
further down the QGIS road. I have never dealt with GIS data but find
it very interesting, especially since I have a drone now and have been
doing mapping with it.
Jon
-----Original Message-----
From: Andrea Giudiceandrea via Qgis-user <qgis-user at lists.osgeo.org>
Reply-To: Andrea Giudiceandrea <andreaerdna at libero.it>
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Oriented Minimum Bounding Box
Date: Sat, 17 Sep 2022 00:19:42 +0200
Hi Jon,
I apologize, but I think I don't understand exactly what the problem
is.
Anyway, if you need a unique "Oriented Minimum Bounding Box" that
encloses all the features in the layer, then - as you probably already
found - you can use the "Minimum bounding geometry" processing
algorithm
specifying the "Minimum Oriented Rectangle" method in the "Geometry
type" parameter and without specifying any field in the "Field"
parameter.
Regards.
Andrea
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
